Fault code 1264
    Fault code 1264
    EGO Heater, no vacuum leaks, after reseting ECU, car will idle without code, as soon as the throttle is blipped once, the CEL blinks, then on the second blip, it stays on. Anyone experience this before? There are absolutely zero leaks, I just changed the intake manifold gaskets, as #6 had a tear and was leaking bad, but now there aren't any leaks and it's still doing this. I'm getting piss-poor fuel economy too. Any help is appreciated. Thanks.
    Keep it slideways!!
    Have you checked the heater relay and the lead from the DME control unit as well? Could be either of these.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
      Which relay is the EGO heater?
      Keep it slideways!!
        the relay closest to the power steering fluid reservoir, in the seperate block of 3 relays.
          Damn, i was hoping for a number, I moved my relays to the firewall under the M42 wiring cover.
          Keep it slideways!!
