I'm having an issue with my car dying around idle speed. When I first start it up it sits at around 800rpm and revs itself oddly, just up down up down with small variations in timing.
After driving for a minute or 2, when I slow down to idle speed the rpms just keep dropping and the engine dies. Sometimes it will get to the very brink of dying and then kick back on.
If I hit the throttle at all, I don't have this problem. I've taken to just putting it in neutral and holding the gas and brake at the same time to try and keep the speed up...it's embarassing when you're at an intersection and have to restart the car 3 times in a row.
Anyone know whats causing that? I don't know if I'm explaining the problem very well. My first instinct was the oxygen sensor but I'm not sure.
Any help is appreciated...
87' 325e by the way.
