I have an 89 325i with 179k and I have started experiencing some really weird problems with the coolant temp gauge and the engine losing power at the same time.
Problem 1: The car starts fine and usually drives fine until it is fully warmed up. Then all hell breaks loose.... At normal cruising speeds, regardless of what gear or where the tach is in the rpm range, the engine will suddenly lose power and nearly shut down. I have to downshift to second and sometimes to first and smash the accelerator to get the engine to respond and recover from its sputtering and loss of power. Sometimes I get a slight backfire and then it will rev up and run great. Idle is also somewhat rough following each of these "exciting" experiences.
Problem 2: My coolant temp gauge in the instrument cluster consistently reads slightly above the center mark on the gauge. Sometimes when the headlights are on the gauge will read very near and sometimes into the red area of the gauge and then the CHECK ENGINE light will illuminate. If I turn the headlights off the gauge will return to normal and the CHECK ENGINE light will go off.
Both problems are usually concurrent. I have recently replaced the timing belt, tensioner, water pump, thermostat-80 deg, oil pan gasket, and drive belts. I have owned BMW's for years: 95 M3, 95 325is, 93 325i, 90 535i, 88 735i, 88 635csi, and 86 528e, but this is my first E30 and I have never had any experiences like this. Other than replacing the ignition parts, wires, distributor, plugs, etc., I am not really sure to begin with these problems. Any help or advice is greatly appreciated.
R.I.P 07/01/09 - 04/23/10 :(
