How much do you think it will cost to repair these problems?
  • royalflush313
    • Mar 2004
    • 2070
    Just seeing if anyone knows how much it might cost on a M3 to get the following problems fixed:
    Right ball joint
    right tie rod end outer
    Power steering pump bushings
    rear cross member bushings
    right sway bar link broken of shock
    CAT starting to crack at rear welds
    rear muffler loose on clamps
    oil leak on timing chain tensioner and cam housing
    play on rear diff axle joints
    rusted threw on left lift front block
    And i guess it wouldn't hurt to replace the chains (belts) while I'm at it. Oh and not DIY pricing, pricing if I take it to a reputable mechanic..
    ~ Go Canucks Go! ~
