Car: 1989 325is
problem: hard to start when its cold.
Check engine light on. Checked for codes. found coolant temp sensor faulty. Replaced it. same problem ! same code. later found out that there was a faulty connection at the harness. fixed it! No more check engine light.
But car is still difficult to start when cold.
One day i had a hard time starting it. when it fired up i accelerated the rpms high. Check engine light flashed but then turned off. Check for codes the next day.
- O2 sensor control
- Vehicle speed sensor control
you think thats my cold start problem ????
- O2 sensor control
