Starting from first and continuing onto second gear, each time I accelerate there is a rumbling noise from the rear. After second gear and so on, it's fine. At first, I thought it was because the tires weren't gripping in first and second gear. They are pretty low on tread but definitely not bald, so I assumed the tires were slipping. Another guess at the time was that the rear driver side tire was really low on air. I filled it back up, but didn't solve the problem. The rumbling is so loud, it feels like the car is about to fall apart. I can't quite tell which side it is coming from. It sounds like both. A buddy of mine said he thinks it's the driver side.
Here's any extra info, just in case..
Bilstein shocks
3.73 LSD
Running spacers, but with long studs
Uhh.. not quit sure the offset or how big the spacer is..
The spacer looks about an inch thick.
but here's a pic..
Any ideas?
Bilstein shocks
3.73 LSD
but here's a pic..
Any ideas?
