I have a 85 318i that i have been working on getting running smoothly so I can get the suspension and brake systems worked over before I do a s52 OBD1 swap. Background on the car is lots of PO modifications, it has rear disc brakes, 5 speed trans, bumper swap, and sport interior. I have been trying to fix the problem of a surge in power under acceleration, low power, and a hunting idle. things i have done/tried;
-ecm
-iac
-idle controller
-full tune (cap,rotor,wires,plugs)
-air flow meter
-vaccum leak test repairs (smoke tested)
-fuel pump(s)
-baro sensor
-tps
-cleaned/disassembled TB
-valve adjustment
-timing
-coolant temp sensor
-fuel filter
-ignition control
odd noted symptom, the SI sometimes is red flashing 3 leds, one orange, or an INSPECTION light, i reset, and then with the car running, the lights spazz out and go to inspection again, could this be an, or the issue?
Im gonna go nuts trying to get it running, only to pull the engine to put in the s52, i dont know what else to try. I have had the ability to test most of this stuff as I am a service manager in a shop that is a major Worldpac buyer. I know all the parts ive tried where good, so I dont know where else to look, any suggestions? Any ideas would be useful because Im about to loose it.
-brandon
-ecm
-iac
-idle controller
-air flow meter
-fuel pump(s)
-baro sensor
-tps
-valve adjustment
-timing
-fuel filter
-ignition control
-brandon
