low speed rear clunking
  • Jordan325iC
    • Aug 2005
    • 1697
    I'm getting a noticable rear clunking when I'm turning slowly to the left or right. It only happens when I'm turning, and from what I can tell it only happens when I'm at low, parking lot speeds. Possible it happens at higher speeds, but I've never heard it. I recently swapped suspension. Thoughts?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • lordofthewaters
    • Oct 2005
    • 714
    cv joints? Ball joints.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • mrsleeve
      • Mar 2005
      • 16387
      I have the same mystery noises???? I am quite shure its the muffler banging on shit and rubbing on the wheel since it only dose it when the big tires are on it.
      Originally posted by Fusion
      William Pitt-
      • DaN
        • 1265
        My old eta had rear brake pads that rattled in the brackets. check if the pads are loose.
        • PУCCKAЯ_e30ka
          • Jan 2006
          • 1226
          do u know cond. of your bushings? (sub.+tral. arms) just a thought....
          • jhower08
            • Jan 2005
            • 494
            mine does it too... i think its normal ;-)
            • emi325i
              • Oct 2006
              • 356
              my brother's axles had some loose screws... i don't know what those things are called.. they're sitting in a circular pattern just off the differential output shafts
              • etxxz
                • Feb 2006
                • 2085
                clunking during right hand turns eh? i had the same problem. check your CSB (center diff bearing/bushing) or it could also be your cv joint in the rear axle in which case you might as well buy a new axle. its an easy job, at least a lot less tedious than the csb. good luck keep us informed
                No more e30s for me.
                88 black BMW OBDII 332is dedicated track [sold]
                88 BMW OBDII bronzit 332is [RIP 03/08]
                91 BMW 325i [sold]
                86 Corolla 'Ae86' HB 20v trd [sold]
                http://youtube.com/watch?v=pTj7Hn9v5Rs
                • Keith M
                  • 2338
                  Do you have a LSD? My wifes e36 (3.23 LSD) makes clunking noises sometimes while turning at low speeds.
                  Keith
