Fuel Pump...
  • formula driver
    • 2263
    Fuel Pump...
    If a fuel pump is bad than the car wont run at all correct? Or am I wrong?
    -Paul
  • redhatpat
    • Aug 2005
    • 656
    Depends how bad it is. When a fuel pump starts to go it'll make a loud whine noise that gets louder as the pump gets worse. I had this noise, but the car drove fine until I replaced the pump. My mechanic said the car stalled out when they were driving it onto the lift, so I guess I cut it pretty close driving there.
    • MikeE30325i
      • 2356
      it might run, depending on the condition of the fuel pump. it might lose 'power' and will fall behind on the fuel needed at high rpm's, but if you can hit redline and the car doesnt sputter or anything and the car idles fine then you should be ok. but change it if you wish. its never a bad idea.
      • AdamF 88iS
        • 2051
        On E30s, generally, the car will be totally dead.
        Occasionally on E32/E34 cars you'll get a pump that has cracked its housing and can't maintain full pressure.. the car will start and idle normally but have shit for power when you try to drive it. I've never seen an E30 do that though.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • formula driver
          • 2263
          Thanks guys!
          -Paul
          • jmarch
            • Oct 2004
            • 163
            Hey Adam,
            For those of us who wait too long to change fuel pumps is there a way to temporarily get a car with an in-tank pump going? I remember tapping an external pump (much like a starter) could get you home (sometimes).
            BTW, I ordered the suspension parts and have an appt with West End on 2/9. Will you be around?
            1995 Porsche 993 6 speed
            2001 BMW M3 6 speed - DD
            2001 BMW 530iA Sport - Hers
            2005 KTM 450EXC 6 speed
            Gone:
            1988 BMW M3 2.5 EVOIII Clone
            1988 BMW 325is x2
            1985 BMW M635CSI 286hp
            2001 KTM 400MXC
            • AdamF 88iS
              • 2051
              Originally posted by jmarch
              Hey Adam,
              On E30 in tank pumps banging on them will work sometimes.
              I'll be around on the 9th, yea.
              Adam Fogg- '88 M3
