So my 325i was smoking a little on start up and then went away. It was basicaly once it turned over, a puff of smoke would come out and then it would be done. Then at the track day after a 20-30 min run group, I parked the car. When I started it back up 45 min later or so, it was smoking bad so I shut it down and didn't drive it the rest of the day until it was time to go home. Made it all the way from Willow Springs to Temecula with no problem. Smoked onstart up, but once I was driving for a bit it went away. I thought it was the valve guides so I was told to run a compression check on the motor. Dry first and then wet and if the compression went up a fair amount then it would be the rings on the pistons, and if not then it would be the valve guides most likely. I ran the test and the compression was all in spec wich leads me to believe it is not the valve guides. However, now that I think about it, the Bentley said to test the engine at normal opperating temperature and at that temp, it may have expanded things enough to give me good compression even though the valve seals/guides are bad. Regardless, what is everyone's take on this? Any other tests I can run to find out what the problem is?
Cheers,
Brian
Cheers,
Brian
