Hey everyone, hope you can help! it's coooold!
Basicly my heat and AC do not work, Quick history... It use to work, started to give me problems on 1 2 3 ( so i figured resistor )..Then fuses started to blow 2 30 amps, 1 controls heat and aux fan , other one no idea ( i know my bad ). any who. it stoped working on 1 2 3 totaly, then stoped working on 4 on the way to my mechaics, it just started to blow cold air and then stoped then came back on and I noticed the temp gauge climbing quickly so we got off chilled with it on for a 15 minutes, and it was all good ( heat worked only on 4 no resistor needed right ) . I don't actually think the car over heated but better be safe then sorry. Still have no idea why it did that it hasent happend since then.
So I went to my mechaincs , changed the resistor with him, that dident work. Changed the fan control switch, still nothing,. Took the blower out, tested all the wires. everything looked good.. So I left the car with him and I think he is going th change the blower... has any one had this issue? could this be because the car may of not had the heat rad recall done? Help Please!!!!
