alright this one has got me stumped, my brake light check will come on when i use my left turn signal, not always the first time but early in the drive if i hit the left turn signal the check light comes on and stays on the rest of the time.
another brake light check thread
have you gotten out of the car or had a buddy check your lights? maybe that light is telling you something. then check and make sure you didn't blow a fuse, and also check that you have the right bulbs.
91-318i SOLD : (
91-318IS for sale
95-740i DD
84-Monte carlo SS Under construction
90-T-bird Supercoupe DD
I know there's a check light relay for the rear bulbs in the trunk--they sometimes go bad. Or maybe your tailights are cracked or the rubber seal has deteriorated, letting moisture cause a short. Those are the only two things I've come up with that could cause both our problems.1988 325ic Automatic
possible i do have a crack and a small hole (to let the water drain back out ) in my left tail light... makes senseYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.
Originally posted by NC325iC View Postbulbs are fine, im not an idiot
91-318i SOLD : (
91-318IS for sale
95-740i DD
Originally posted by NC325iC View Postpossible i do have a crack and a small hole (to let the water drain back out ) in my left tail light... makes sense
It's hard to find a pair of used ones that aren't cracked. Both of mine have cracks in them, so I'm pretty sure that's what's causing my problem.1988 325ic Automatic
ill see if i cant do something without replacing the lightYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
