What type of transmission oil to use (pics)
  • Panda
    • Jul 2006
    • 35
    I'm going to be changing my transmission oil tomorrow. I've been reading about how theres three different kinds of oil to use depending if you have a red, green or no sticker at all on the side of the transmission. I got a chance to get under my car today and I think theres a red sticker and took some pictures because I'm not exactly sure because the sticker is pretty worn out.
    And if it is red that would me I use ATF?
    thanks,
    Dan
    88' 535 4DR | 87' 325 4DR | 87' 325 2DR
  • Mike325
    • Mar 2006
    • 3685
    That looks like the Getrag 260 (manual) tranny. You see that kinda pinkish sticker in the frist pic? You can't really read it anymore, but it says to use atf fluid. And yes, it would be read but there are different colors depending on manufactuer. A lot of people like the redline fluids. You can find them a Turner Motor Sport.
    http://www.turnermotorsport.com/html...GearLubricants
    Originally posted by Kershaw
    • trent
      I run 80W-90.
      • Panda
        • Jul 2006
        • 35
        So just to make it clear that is the red sticker meaning I use ATF?
        by the way here is a little info I found that might help other people;
        FLUIDS CHANGE
        - rear diff drain/fill (1.7 liters hypoid)
        ALL BMW differentials use 75W-90 Gearoil. This is ideal for open or factory limited-slip units, as well as the torque-sensing type if you are lucky enough to have one of those.
        - tranny drain/fill (1.25 liters non-hypoid)
        In the gearbox (manual transmission), some BMW's made between 1986 and 1992 had "labeled" gearboxes with a red or green label on the passenger side of the bellhousing.
        These had 17mm EXTERNAL wrenching oil plugs. If the label is green, use Redline MT90. If the label is red, use Redline D4 ATF. If there was no label,
        the gearbox will have 17mm INTERNAL wrench oil plugs, and should use Redline MTL GL-4 70W-80.
        • AdamF 88iS
          • 2051
          Wipe the crud off of that label. It will say right on it in plain English.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • Mike325
            • Mar 2006
            • 3685
            Yes, atf
            • Panda
              • Jul 2006
              • 35
              Tried that and the sticker just started falling apart.
              So I put in some ATF but heres the question I got now. At the store all of the bottles of ATF said for automatic transmission including the one I picked up...do they make ATF specially for manual transmissions? Is it going to be a problem?
              • backtrail69
                • Jul 2005
                • 4471
                ATF stands for automatic transmission fluid... You put in your power steering as well.
                :: PNW Crew ::
                '87 325 4dr, '74 2002
                • Mike325
                  • Mar 2006
                  • 3685
                  It is made for auto trans yes, but it is used in manual trans as well. You did good
                  • RobertK
                    Kicked cancer's ASS.
                    • Jun 2005
                    • 5864
                    Actually.. there is just ATF and then there is Mercon III crap. Make sure you get the bottle that just says ATF in big letters.
                    I recommend Royal Purple ATF over Redline. The only real difference between the two is the price. Both are made from Group 4 oil.
