wiring 89 M20 into 87 chassis
  • Funkmasta
    • May 2004
    • 7185
    Alright, about to tackle this again...
    We installed an 89 M20 into my cabrio, and tried to retain the 89 engine harness. This has proven to be a nightmare, so we are going to revert back to an 87 harness.
    has anyone wired a late M20 with an early harness?
    thanks in advance.
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
  • James Crivellone
    Head Janitor
    • 6305
    any exact details? the only biggy is bringing C104 on the 87 into C101, I recommend taking an 88+ C101 connector and modding in that into the car.. I did this and its been problem free, and accepts any late model engine harness.
    • Jand3rson
      • 37587
      Yeah, it's a slut. :D
      James is right, it does work just fine.
      • Funkmasta
        • May 2004
        • 7185
        The cabrio is an 87. I parted out a 220k 89 325is that had been immaculately taken care of, and decided that the engine would be a good donor for the cabrio, since it was a great motor, and few people would be willing to buy a 200+ motor.
        SO,
        we tried to install the 89 M20 into the 87 cabrio, using the 89 engine harness.
        No worky.
        Would it be easier to swap back to an 87 harness? Or should I mod the plug?
        At this point, obviously the easiest fastest fix would be best, but also I need something reliable.
        Thanks!
        Joe
        That Guy.
        • James Crivellone
          Head Janitor
          • 6305
          SO,
          No worky.
          Thanks!
          Joe
          Least hassle, 87 Harness...otherwise you gotta pull 3 wires deep inside the dash, to run them over to C101 (correctly anyway)
          • Funkmasta
            • May 2004
            • 7185
            Cool, 87 harness it is.
            Any difference in plugs on the motor? Do I have to mod the harness to work on the 89 block?
            That Guy.
            • James Crivellone
              Head Janitor
              • 6305
              88+ use a fuel rail harness for the injectors, instead of individual plugs like the 84 - 87 models..
              Just rip that fuel rail harness off and use the individual plugs.
