Torque wrench for the valve cover...
  • JDMpower
    • Sep 2006
    • 1771
    WTF - How do you do it? I only have a 2' long torque wrench from 10ft-lbs to 300ft lbs. It will not even fit between the intake manifold to get the two center bolts (2 and 3). So how do you do it? Tell me I am not going to need to take off my intake - plus I do not like the fact that I am using such a big wrench to do such a small nut. I do not want anything to break.
    '89 "is" = M technic II build mode.
  • JDMpower
    • Sep 2006
    • 1771
    Can I use an inch pound wrench and just stick it on 132 inch pounds to get the desired 11 foot pounds? Seems to make sence....
    • SchnellerVert
      • Sep 2005
      • 3948
      Pricey but very nice, SKMicrometer Torque Screwdrivers
      Discover the SK Tools Sktools.com, built for professional performance, lasting durability, and reliable results in the shop or garage.
      • euroshark
        • Apr 2006
        • 3491
        You can tighten the valve cover by hand... Its NOT crucial to get exactly 11ft/lbs. Important things to torque: Half shaft bolts, cylinder head bolts, rod bearings, etc. Valve covers... not really, just get them "tight" by hand, but not too tight.
        • kommissar
          • Dec 2005
          • 402
          Yes, that's legal. Convert 11 ft/lb to in/lb... 11 (ft / pound) = 132 in / pound
          • JDMpower
            • Sep 2006
            • 1771
            Thank you!
              • 37832
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • ak96ss
                • Nov 2005
                • 461
                FWIW, I use an 'old-fashioned' beam torque wrench, like this one:
                http://www.sears.com/sr/javasr/produ...id=00944690000
                John in MD - 1991 318is
                190k miles and still rolling!
                • euroshark
                  • Apr 2006
                  • 3491
                  lol...
                  Do you torque your distributor cap bolts too???
                  • SchnellerVert
                    • Sep 2005
                    • 3948
                    There are people out there that do hence why there is tools for doing it.
                    • euroshark
                      • Apr 2006
                      • 3491
                      Fair enough, I guess if having everything set at a specific torque sets your mind at ease, more power to you! I'm good with having the driveshaft bolts, starter bolts, bellhousing, motor mounts as tight as I can get em, same with everything else but the head... "Tight is tight, too tight is fucking broken" - my favorite automotive quote.
                      • porsche gt1
                        • 237
                        that is what I used on my last opening of the valve cover. Worked great, especially with an extender.
                        • JDMpower
                          • Sep 2006
                          • 1771
                          I am just anal with the torque settings. I mean, if it is in Bentley, I might as well do it right when I do it.
                          I bought an inch pound wrench, and did the math. We are all good now. Next is the intake manifold. :)
                          • ivo316
                            • Oct 2006
                            • 1222
                            I did not torque my valve cover, it kinda "perspires" oil, I guess i will when I replace my valve cover gasket again. :(
