Bucking when engine is cold
  • ACHTUNG
    • May 2005
    • 2397
    I have a 1989 325i. When the outside temp is aprox below 35 degrees, I start the car up and always let the motor warm up for aprox. 2-5 min. before driving.
    The car starts to buck when I start to drive. Once the engine is totally warmed up, the bucking stops. What could cause this? how do I fix it?
    Thanks!
    1989 US E30 Cammed S52
    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
  • MikeE30325i
    • 2356
    you cant. it is just how the car drives when it is cold. its just natural.
    • ACHTUNG
      • May 2005
      • 2397
      How is this "natural?" It just started doing it this winter. If it was natural, all of our cars would be bucking when cold.
      • brandondan1
        • 1091
        Did you hit the secret "Rodeo" switch?
        It may be a fuel issue. I would replace the fpr and spark plugs if you haven't in a while.
        91 318is
        • MikeE30325i
          • 2356
          my car hesitates and bucks when the engine is cold. but as soon as the engine temp gets higher, and the idle goes down to 600 rpms, the bucking goes away.
          it could be that the oil isnt warm enough and covering all the parts of the engine like it should, and maybe parts are rubbing or something, causing the bucking. good luck trying to fix it.
          • NC325iC
            • Mar 2004
            • 6565
            my engine gets a very slight hesitation when its cold, but only sometimes, so far it hasnt worried me cause its not real bad right now
              A cold engine requires a richer mixture and even a small intake leak can lean out the mixture enough to cause problems. That would be the place to start in solving this problem.
              • ACHTUNG
                • May 2005
                • 2397
                I'll start with that. Thanks.
                • asubimmer
                  • 6482
                  • porsche gt1
                    • 237
                    I have the same problem. I do not have a leak in my intake or anywhere else (i know this as I just replaced all my gaskets 2 months ago).
                    • HST
                      • Jan 2006
                      • 757
                      This hapened on my E39 this winter, it was an intake leak, I did the valve covers, manifold, and throttle body gaskets, then every vacuum hose I could find. I also replaced every hoseclamp that was on every vacuum hose.
                      Originally posted by KingB
                      Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
