lowish vacuum
  • E30godz
    • 1524
    lowish vacuum
    I have been noticing lately that my engine vacuum has gone from 18-17 hg/inch to about 14 or 15 hg/inch. I assumed vaccum leak but checked the usual suspects and found nothing. The car also runs fine/idles fine. How much of a chance is there that i fucked a piston ring? car has 130k miles now and has just recently begin boosting about 5-6 psi for short instances. guess ill whip out the compression tester
    also i could tell no difference between the numbers of the compression test when the throttle shut, or completely open. I also had all the spark plugs out.
  • m42technic
    • 1056
    Uhh... youre running a turbo, wouldnt you inherently have less vacuum?
    James Peacock
    WWFSMD?
    • E30godz
      • 1524
      well....not at idle....on further investigation, when the car warms up its only about 1 inch/hg less than it used to be.i may just not worry about it
      • E30godz
        • 1524
        did a compression check today.
        150, 142, 135, 141 150 147.
        these were done on an engine that had beens sitting a around 2 hours probably?
        TCD recommended that i switch to mobil 1 10W-30 instead of of staying with the 15W-50
        car idles fine, vacuum is low on startup (about 11-12 hg/inch and when its warm its around 16 hg/inch.) the car is also happy to build 6-7 psi and spikes to 9, to 5000 rpm. since i had problems with the 30 lbers, i swapped in some 19's and dump fuel at WOT. pulls very very hard. Im not going to get over 5grand untill i work out the extra fuel problems. I also mounted my boost gauge right behind the steering wheel...looks great there.
        • PeterCip
          • 402
          what to you mean it spikes to 9.. mine build to 11 almost instantly and holds there.. ther are no spikes what-so-ever. what turbo are you using? the only other person I heard about this spiking from was bimmerjim, and he seemed completly incompitant.
          -p
          • E30godz
            • 1524
            its a wastegate thing.
            • E30godz
              • 1524
              all boost spiking is, is when the turbo builds boost faster than the wastegate can respond, usually only happens for a second or two and then settles down. Like ive im off the gas at 5 grand and then floor it, it spikes up to 9-10 PSI and then settles down...external wastegates have this problem less i believe.
              • E30godz
                • 1524
                ok, Update....the problem mysteriously went away! and the vacuum and everything was back to normal...idling at 17-18 Hg/inch.....BUT i put in those turbo spark plugs (W5DC) and the fucking problem came back! now..what would you suppose this is? i have my thoughts but id rather hear some others
                • DaN
                  • 1265
                  If you aren't noticing any performance problems, and there are no vacuum leaks, then don't sweat it dude. You'll live longer. ;)
