NEEDED BADLY: M42 pinout chart
    I need it something fierce.
    I always come through for you guys. Time to give back.
    lol
    help?
    Need C101 pinout chart for 318is. I assume it is different than M20.
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
    What year, I might have the ETM
      91 318is
      lmk thx
      That Guy.
        What is a pinout chart ?
        I might have it, but I'm a spanish speaker and don't know what it is.
          It's the chart that tells you pin numbers and wire colour for different electronic sockets.
          Most of the colour are the same m42->m20, but don't know about pin locations.
          Current:
          BMW 320i 2d 2.0 m20 -88
          BMW 325i Cabriolet 2.5 m50 -88
          BMW 316i touring 1.6 m40 -90
          BMW 320i 4d 2,2 m54 -01
            Sorry for the format, this is from a huge excel spreadsheet I've been compiling of c101 pinouts :)
            Columns are as follows
            Pin #-size wire-Color(chassis side)-Size-Color(engine side)-description
            91 318is
            Pin # Size Color Size Color Description
            1 Small Blue Small Blue Battery Light
            2
            3 Not Used
            4 Small Brown/Violet Small Brown/Violet Coolant temp sender
            5 Small Black/Brown Small Brown/Green Oil Pressure Warning
            6 Large Green/Yellow Small Green/Yellow Fuse 9/pin 16 diagnostic Connector
            7 Large Green Large Green Start Input
            8 Small Yellow/White Small White Fuel Rate output
            9 Small Black Small Black Engine Speed
            10
            11 Small White/Blue Small White/Blue SI reset input
            12 Small Brown/Black Small Brown Check engine light
            13 Large Violet/Red Large Green/Violet Fuel pump relay pin 87
            14 Small Blue/Yellow Small Black/White Speed Output/Input to ECU
            15 Small Black/Green Small Black/Green Pin 85 Unloader Relay
            16 Small White/Black Small White/Black SRS Diagnostic Connector
            17 Not Used
            18 Large Black/Yellow Large Black/Yellow Starter
            19 Not Used
            20 Small Red/Yellow Small Red/Yellow Power ABS unit
            85 325e 2.7 ITB'd stroker
              91 318is
              2
              3 Not Used
              10
              17 Not Used
              19 Not Used
              BEAUTIFUL.
              THANK YOU!
              Any Idea where I can get the pinout for the body side plug for an 81 320i? ;) It is equally hard to find...
              That Guy.
                If you dont have it by Monday I'll see if I can get one at work for ya somehow.
                Will
                RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                Welcome e30 (brilliantrot '90 325is) 12/23/06
                DaveCN = Old Man
                My signature picture was taken by ME! Not by anyone else!
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                  I have the PDF file of the ETM for the 318iS if you need the rest.
                  Reminiscing...
                    Originally posted by Funkmasta View Post
                    BEAUTIFUL.
                    it I have all the ETMs from the early 80's up to the 1 series:nice: but it only goes as far back as the e24 chassis. Try the e21 tricord forum, as there are a few pages out there covering the m42 swap into the old e21
                      thx for the tricord link, I threw a post up there.
                      We will see how it goes?
                      You cant decode this plug for me, can you?
                      That Guy.
                        uhhh
                        m42 ecu pinout?
                        Motronic Control unit
                        Function Color
                        1 Fuel Pump Relay BR/GN
                        2
                        3 Injectors 1-3 BR/WT
                        4
                        5
                        6 Ground BR/OR
                        7
                        8 Check Engine light BR
                        9
                        10
                        11
                        12 TPS Signal 5v BR
                        13
                        14 Common 5v GY/BU
                        15
                        16 Camshaft sensor input YL
                        17 Fuel rate output WT
                        18
                        19
                        20
                        21
                        22
                        23
                        24 Ignition cyl 3 BK
                        25 Ignition cyl 1 BK
                        26 Power Input RD/WT
                        27 Main Relay control BR
                        28 Ground BR/OR
                        29 Idle Speed Control WT/YL
                        30
                        31
                        32 Injectors 2-4 BR/WT
                        33
                        34 Ground
                        35
                        36 Charcoal Canister control BR
                        37 O2 relay control BR/GN
                        38
                        39
                        40
                        41 AFM Input (5v) GY/YL
                        42
                        43 Common 5v Coolant and TPS BR/BK
                        44 Camshaft sensor input BK
                        45
                        46
                        47
                        48
                        49
                        50
                        51 Ignition cyl 4 BK
                        52 Ignition cyl 2 BK
                        53
                        54 Power Input RD/WT
                        55 Ground
                        56 Start Input GN/YL
                        57
                        58
                        59 Refrence output (Ground??) GY/WT
                        60
                        61
                        62
                        63
                        64
                        65
                        66
                        67 Crankshaft input sensor BK
                        68 Crankshaft input sensor YL
                        69
                        70 O2 Input BK
                        71 O2 Ground YL
                        72
                        73 Speed Signal input BK/WT
                        74 Engine Speed Output
                        75
                        76
                        77 Air temp input GY/VI
                        78 Coolant temp input BR/RD
                        79
                        80 Diagnostic voltage GN/BU
                        81
                        82
                        83
                        84
                        85 A/C Input BK/GY
                        86 A/C Input BK/VI
                        87 RXD Diagnostic WT/YL
                        88 TXD Diagnistic WT/VI
                          damn, i subscribed to a day at bmwtechinfo.com....but that was a while ago that would have what you are looking for though
                            Splice the orginal harness and tell me the colours of wires and I'll translate :) pretty much colour to colour.
                            Current:
                              Will do tomorrow.
                              That Guy.
