brakes.
  • eyagel
    • Jan 2007
    • 756
    brakes.
    is doing brakes on e30's very hard?
  • Van Westervelt
    • 9365
    No, its actually very easy. Did all mine in 40 min in the dark once.
    • eyagel
      • Jan 2007
      • 756
      awesome.. i didnt know sometimes those germans do some crazy stuff.
      • kommissar
        • Dec 2005
        • 402
        Just make sure you have a good size breaker bar to break loose the two 19mm bolts that hold each caliper on. They are tight to begin with and sometimes they get a bit rusted-in-place.
        • BigD
          • Jul 2006
          • 1085
          Just make sure you get the setscrew out of the rotor before you start removing anything else. Cause until you get that out, there's no point in continuing.
          • mrsleeve
            • Mar 2005
            • 16387
            yeah the set screw can be a bitch if the last time there was no antiseize put on it. Antiseize them an you wont have a problem next time. If you do strip it out get a drill bit an drill the head of it off.
            Originally posted by Fusion
            William Pitt-
