HELP: Stripped the rotor bolt in order to get it off...
  • H&Re30
    • 242
    well, my friend and i are repairing his rotars and pads...
    got the pads off just fine, but then stripped the bolt...
    one question, is the bolt a normal thread, or a reverse thread?
    thanks for your help...
  • SchnellerVert
    • Sep 2005
    • 3948
    Drill out the head or use a BFH Big F#$%ing Hammer and knock off the rotor the head will shear.
    • NC325iC
      • Mar 2004
      • 6565
      what he said, no big deal here, if you have a spare one layin around use it as a guide for the right size drill
      • Kilomph
        • Oct 2004
        • 599
        Normal.
        • trent
          use a drill, the bolt is not necessary for reassembly.
          • mrsleeve
            • Mar 2005
            • 16386
            Yup drill the head off an put it back togeather.
            Originally posted by Fusion
            William Pitt-
            • AdamF 88iS
              • 2051
              Originally posted by Kilomph
              Normal.
              Only when the person that did the job last tightened the hell out of it or didn't put any brake lube on it. There was a guy I knew at a local dealer here that would install those with an impact wrench. He never did seem to realize that those are just for convinience during assembly and the wheel bolts are what really holds the rotor on...
              Just lightly snug them down and you'll never have a problem. If you live in a wet or salty area, put a little anti-seize on em.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • Funkmasta
                • May 2004
                • 7185
                BFH, hit the rotor from the inside out, 180 degrees from the bolt.
                snapppppalicious.
                Joe Funk -- Portland Oregon
                That Guy.
                03 X5. 3 liter obviously.
                • Brew
                  • 3060
                  ALWAYS remove those with an impact wrench.
                  '91 318is
                  • 96 Cosmos
                    • Jan 2006
                    • 366
                    Bumping this because this thread really helped me out. BFH FTW!
                    • abepark
                      • Feb 2006
                      • 384
                      anti seize is your friend! always put it on with installation! makes the next time much easier.
