Windows stopped working
  • 02stu
    • Jan 2005
    • 872
    Both of my windows stopped working today, unfortunately the drivers window is down. The wiring diagram that I have for the car, its a 318is, is wrong since the colors in the switch and the colors in the manuel are not the same. What wire would I need to supply 12V to to put the window up? Any ideas on why the windows stoped, the fuse is fine and the breaker is not up.
    Thanks
    Stu
  • MikeE30325i
    • 2356
    us the little allen key in your trunk tool kit and pop off the little plug on your door and roll that bitch up.
    • 02stu
      • Jan 2005
      • 872
      newer models don't have that feature unfortanitly
      • browntown
        • Jun 2004
        • 3524
        if they both went out together, most likely culprit is a fuse, check em.
        • MikeE30325i
          • 2356
          ah damnit, i now know that.
          good luck on a fix.
          • AdamF 88iS
            • 2051
            Thanks
            Stu
            Are both wires still there on teh back of the breaker? Check fuse 17?
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
