Messed up injector tip
  • BigD
    • Jul 2006
    • 1085
    I'm putting in the pink tops into my M50 manifold and I had a close look at them. They all look good except a few of them have what look to be melted fins around the nozzle... is this normal? Is it a sign of something bad happening to the engine? Should I replace the ones that have this?
    This is the worst one:
  • BigD
    • Jul 2006
    • 1085
    I had a look inside all the intake ports, they all look clean and shiny like this one. It's bugging the crap out of me... the S52 intake manifold is perfect. The seller is a very kind and trustworthy person, he wasn't even intending to sell the engine, he had it in his restoration shop (mint 2002) to put into his 318 but he wasn't interested in that anymore so I convinced him to sell it. He said the compression figures were all good... can I test compression by handcranking the engine? (ie just turn the crank bolt)
    • pineapplegti
      • 340
      if your worried about the engine u should leak it down. no need for a starter
      • BigD
        • Jul 2006
        • 1085
        Well, looks like my paranoia is unfounded. The seller said that the manifold on the original was broken, they replaced it with the manifold and injectors from a 328. They did do a compression test on the S52 and it was around 165-170 across the board...
        But back to the injectors, should I replace the gimpy looking ones? Or get them flowmatched?
        • 92 mtechnic cabrio
          • 4907
          don't skimp on your swap, buy new injectors and sell those to someone that is okay with doing a half-ass job
          R.I.P 07/01/09 - 04/23/10 :(
          • FredK
            • 14763
            What the hell happened to those injectors!
            I have good 70k mile pink top 21.5 lb/hr injectors that I'll sell for $60 shipped.
            I don't think pintle caps are available separately.
            • RobertK
              Kicked cancer's ASS.
              • Jun 2005
              • 5864
              I would be more concerned about what was wrong with the engine to cause it to do that to the injectors.
              Otherwise it's like pulling a prematurely fouled spark plug and just replacing it with a new one without fixing the issue that caused the original plug to foul.
              Only injectors are much more expensive than spark plugs.
              • trent
                do it right and have the injectors sent out to be rebuilt..
                • BigD
                  • Jul 2006
                  • 1085
                  Yup, that's what I've decided on. Any recommendations on the shop?
                  Don't care anymore. Like I said above I contacted the engine seller and he told me the original manifold was damaged and they replaced it with one from a dead 328 (not for me, but he was planning to put it into his car like this).
                  • trent
                    I use RC Engineering here in CA...but they seem to be about double the price of Witchhunter? I Think do a search for it
                    • BigD
                      • Jul 2006
                      • 1085
                      heh, I just did... seemed to find a good thread until I opened it...
                      And just incase the thread is temporarily fucked, here's a screencap of what I saw:
                      • trent
                        Hahahahaha
                        • FredK
                          • 14763
                          Wow, what the hell happened to that thread? hahahaha
