how to remove REAR AXLE CARRIER?
  • 318i sTiLL FLy
    • Nov 2005
    • 82
    as it state's i cannot seem to get the last to bolt's on the drivers side and passangers side.
  • Rigmaster
    • 3464
    You talking about the diff??
    If so, there are 4- 19mm head bolts on top of the subframe that hold it- you should be able to get a regular combination wrench on all of them enough to get them loose- use the box end on the bolt and put another wrench on the open end to get more leverage and they will come loose.
    If that's not what you're asking about- how about some more details??
    Bret.
    • Mike325
      • Mar 2006
      • 3685
      The carrier sounds like the rear subframe.
      Look in the suspension section here. Lots of stuff about everything your heart desires:p
      Originally posted by Kershaw
      • 318i sTiLL FLy
        • Nov 2005
        • 82
        http://www.realoem.com/bmw/showparts...13&hg=33&fg=30
        it's number 1
        need it out tonight i got everything cept the bolt on the sides of the car i got the nut unbolted what i can't get it out !!!
        • Mike325
          • Mar 2006
          • 3685
          That bolt should be nice and tight. 22MM BTW. Get a breaker bar and go at it. The rear subframe is a bitch to get down. I hate to say it, but be prepaired for a long fucking night my friend. Here are some things that may help you out. Good luck.
          • FredK
            • 14763
            Yeah this thread should be pretty informative:
            After removing those nuts, hit the long bolts that go through the subframe bushings with a big hammer.
            Then, you have to pry above the thick washer and the body to make the subframe drop, because the subframe bushings have a little metal cylinder that resides inside the car's rear floor.
            • turbo_negro69
              • Dec 2006
              • 468
              sounds like a can of PB blaster would be your best friend right about now;)
              91-318i SOLD : (
              91-318IS for sale
              95-740i DD
              84-Monte carlo SS Under construction
              90-T-bird Supercoupe DD
