Tach Mpg and Temp
  • HalexH
    • 79
    Tach Mpg and Temp
    I have done all the searches and nothing helped. I have replaced the Si batteries on 2 Si boards. And changed out 2 diffrent clusters. All of my gauges work but the Tach is never steady it jumps about 100 to 200 rpms constantly and the Mpg gauge just swivels in between 5 and 15. As for the Temp it shows accurate readings but it jumps around at the same rate as the Tach. Anyone have any ideas what could fix this.
  • HalexH
    • 79
    (Bump) anyone have at least clues to where I should start looking.
      Could be a ground or power supply problem. Check those circuits out with a meter.
      • HalexH
        • 79
        Any idea how the cluster is grounded. I am getting my Bentley today or tomorrow that would have it right ?
        • Jesse30
          • Jan 2007
          • 3936
          my cluster does the same thing. everyone i've talked to says i need to replace it completely
          • HalexH
            • 79
            The thing is I replaced it with a cluster from a car that worked perfectly fine.
