I smell (and see) gas. Can't see where it's coming from.
  • kencopperwheat
    King of Kegstands
    • 14396
    I was driving a smelled gas. I pulled over, popped the hood and the smell got MUCH stronger. I smelled the fuel rail and it was really strong. Then I noticed a small puddle of liquid (it was gas) that had collected on one of the crannies of the intake manifold. I *think* one of my fuel injectors might be leaking it. I touched the one next to the puddle and it moved (it wasn't screwed in tight). How tight are the injectors supposed to be screwed into the manifold? Would this cause a lot of gas to leak if one was loose?
    It's too dark to see exactly where the leak is coming from right now.
    I hope this leak will explain my horrible gas milage (below 25mpg right now).
    Originally posted by Gruelius
  • Jordan
    • 12916
    Stop driving the car until you fix the issue Ken. I'm not joking. I've heard of soo many e30's that burned to the ground from fuel leaks in the engine bay.
    check the orings, make sure the injectors are seated and secured right etc.
    https://mtechniqueabs.com/
    • kencopperwheat
      King of Kegstands
      • 14396
      I'll check the O-rings tomorrow when I can see.
      • 325 eta
        • 472
        in your engine bay check that little blue sensor. thats what was leaking gas in my car. you can see it in your sig. i dont know the name of it. sorry it fixed my gas smell
        • M-technik-3
          • 18946
          Check the rubber fuel lines too. Don't drive it, I screamed at my wife the other day for doing the exact same thing except she drove it to the dealer to be fixed. Brave woman, or stupid? I married her sometimes I wonder, and it'll be 10 years next month.
          Seriously gas will ignite on fumes, that is why it's so dangerous. It's flashpoint is lower than 86.8 degrees Celius. Low temp.
          • kencopperwheat
            King of Kegstands
            • 14396
            Bingo! I just ran my finger under it and it reeked of gas.
            Cold-Start Valve, correct? Why would it be leaking?
            How hard was it to replace yours? Do you replace the whole thing that goes into the manifold?
            Is the cold-start valve the same for all e30s?
            I don't think it's the injectors, I just checked with a flashlight and it's dry as a bone around all of them.
            • bimmerphile
              • 3495
              Just get under the car, and use a lighter or something to get a better peek at it.
              • kencopperwheat
                King of Kegstands
                • 14396
                I have bad eyes, you'd better take a look for me. I have a butane torch if the lighter isn't bright enought.
                • 325 eta
                  • 472
                  just the blue thing. plugs right out.
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    From what I can see, the blue thing is just the electrical connection to the cold-start valve. How could that leak? There isn't even a fuel line going to it.
                    • 325 eta
                      • 472
                      well mine had a crack by the metal clip, when i relpaced it. it fix my problem
                      • matt325is
                        • 409
                        The blue thing is a cold start injector, not the ICV. The cold start injector injects fuel to enrich the mixture during cold starts, to warm up the car faster. Sounds like it could be the candidate for the leak.
                        matt
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          So you just replaced the electrical plug?
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            matt
                            Nobody said it was the ICV, LOL.
                            Where would it be leaking from? Is there an O-ring seal on it or something?
                            • matt325is
                              • 409
                              Well, the blue thing is the electrical connector for teh cold start injector. The injector where it seals to the intake manifold or at line leading into the injector.
                              matt
