vibrating fuel pump
  • pineapplegti
    • 340
    vibrating fuel pump
    what up guys i just got done replacing a control arm due to the recent snow on the 58 rev'ing my car lmao .. anyways since i was working on the car i went to address my mystery vibrating fuel pump. The pump was replaced about a year ago. i pulled it out and the housing seemed like it was loose ( the metal brace that the actual pump sits next too.) anyways i shimmed it with a piece of fuel line but i can still hear the pump changing tone . has anyone else delt with this ? thanks
  • lordofthewaters
    • Oct 2005
    • 714
    If you're talking about your 91 325i, the fuel pump is in your tank, and there should be no metal "brace" under your seat.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • pineapplegti
      • 340
      im talking about the chassis that the fuel pump sits on.. i had the fuel pump in my hand today :) trying a borrowed pump tommorow to see if it fixes my problem.. the car is really laying down after 5k
      • Mike325
        • Mar 2006
        • 3685
        Sounds like you are describing an eairly model car's fuel pump. They are located behind the driver's rear wheel. The pump on your car, however, should be in the tank on the driver's side like metioned before. It is mounted in the tank from the top and can not move or vibrate. Are you maybe talking about the filter?
        Originally posted by Kershaw
        • pineapplegti
          • 340
          no what has happened is that the actuall fuel pump that sits in the chassis in the tank vibrates and hits the chassis and makes weird noise.. i was having a fueling problem but i fixed that ( clogged fuel filter ) i was just wondering if anyone else had problems with the actual pump coming loose in the chassis.
          • fretburnr
            • Jan 2005
            • 1496
            i think he's talking about the in-tank pump carrier, the assembly to which the late-model pumps are mounted.
            Jay
            • pineapplegti
              • 340
              update.. ok my fuel filter was clogged to hell.. bad enough where my car would hit 5k and sputter and cough.. the pump is kinda loose in the bracket / chassis so im gonna shore that up before putting it back in. well see what happens.anyways now that that the fuel filter is kosh i have a test pump (e36 318is in a e30 housing ) and it runs great and the pumps noise doesnt change tone. i think the old pump was fighting with the filter..
              • Mike325
                • Mar 2006
                • 3685
                Does it sound better after the 5k thing?
                • pineapplegti
                  • 340
                  well im running a borrowed pump right now and the tone never changes on that now that ive replace the filter.. ill install my old pump prob in the morning.. btw change your fuel filter lmao.. my car feels totally different now :) now i can actually feel the conforti chip
