HELP!! electrical issues
  • e30hereicome
    • Dec 2006
    • 115
    well ive posted a thread about my rpm gauge not working but didnt get much feedback on it. this was 2 days ago. as of now it has completely stopped working. along with that my front/rear lights wouldnt work while the headlight switch is on.(front amber light and rear visual light) headlights work but not the visual lights. along with this my interior light wouldnt work either. the only interior light that works is the window switch lights. other than that nothing else works. its bugging me because i have work during the night and i can get a ticket because my rear right light is out. ive checked the bulb and it seems fine. has anyone experience this problem before, and point me to the right direction towards resolving it? thanks !
  • gerlando
    • Sep 2006
    • 43
    The headlights and parking lights are on different fuses so it's not odd that the headlights work while the others don't Check fuses 23 & 24 to make sure they're not blown. Check all the bulbs to make sure they're not blown. And finally check all the bulb housings to make sure the contacts are clean. It may help to try to bend them out a bit to make better connections with your bulbs. I've personally noticed the rear lights sometimes don't seat well.
    Other than that I'd say get yourself a bentley manual. It has almost all the wiring diagrams you'd need for an E30. It sounds like you have wiring issues throughout your car so check ALL the fuses first and hope that's it.
