2.7L on a budget
  • MattE30
    • 1520
    2.7L on a budget
    I remember this post being on e3s, but I forgot the information, and I am now interested. It is my understanding that you can use eta parts to build an inexpensive 2.7L M20. Shed some light please.
    97 Cosmos M3
  • rwh11385
    lance_entities
    • 18403
    Re: 2.7L on a budget
    As i remeber, the eta crank with i rods, but the i pistons must be shaved a couple mm so they won't hit the valves. The longer stroke + same rod = problem.
    On the other hand, you could get customs pistions :shock: for $850, not really a budget.
    • AdamF 88iS
      • 2051
      You need '88 only SuperEta pistons. They are the best way to do it on a budget. You can use any eta crank and any 'i' head together with those.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • MattE30
        • 1520
        i rods or eta rods?
        97 Cosmos M3
        • rs4pro3
          • 5808
          E rods with super eta pistons. The I rods are to long for the eta crank's stroke.
          85 325e 2.7 ITB'd stroker
          • 65Matt
            • 172
            Can you buy Super Eta pistons new? Anyone know the part number/ cost? I would imagine they would have to be overbored, too.
            Edit:
            Here's a page I ran across that shows the differences between the pistons:
            • Bill 84 318i
              • 1600
              The bore of eta, supereta, and 'i' engines is the same.
              • Fred
                • 659
                Edit:
                http://home.netpower.no/pberg/Mahle_m20.html
                BMW list price is $834 a set, though I'm sure you can find places that carry em for less.
                Fred
                '86 325 2.8i stroker - Arctic Blue
                '11 328i Sports Wagon - LeMans Blue
                Strictly Eta
                • george graves
                  • 20003
                  Uhhhh??? - am I the only one that think $800 for psitons is not exactly a way to go for a budget re-build?
                  George gRaves
                  Originally posted by Matt-B
                  • E30godz
                    • 1524
                    not NEW, i think that should be used as a reference... junkyards and ebay is where to look for a set. easily 100-200 bucks.
                    • Fred
                      • 659
                      George gRaves
                      Like Ian said, that is the list price of brand new pistons from the dealership. BMW's list price for an E30 ABS computer is $900, but they go for like $50 at junkyards.
                      Fred
                      Strictly Eta
                      • modifiede30
                        • 1208
                        I'm in the process of building a stroker based on the super eta. I have an "i" engine in the car, and I was able to obtain the whole super eta free. Aside from replacement parts, I can build this stroker for less than $500 if I do all the work on my own-which I'm doing. I just finished porting the head and intake, and the engine block is bare, the 274 cam was just recieved, and I'm about to buy the bearings and piston rings. These are all that's left.
                        You can find a whole super eta engine relatively cheap. If you do this, replace the cam and buy inner springs and you've basically created an "i" head. This allows you to recoup a good bit of money by selling your "i" head once you've finished the conversion.
                        I've yet to see any performance numbers but even if the horsepower comes to the same as an "i", you've moved your useable torque range down the rpm range about 1000 rpms. As a result, the need to get to 6900 rpms is eliminated, especially since you'll begin to loose torque since its no longer an "i" powerband engine. Here is a breakdown of my costs.
                        Valve Springs: 39.00
                        Head Set: 59.00
                        Block Set: 24.90
                        Cam Regrind: 149.00
                        Porting Kit: 35.00
                        Rod Bearings: 32.90
                        Main Bearings: 38.95
                        Piston Rings: 101.40
                        Total: 485.15
                        Not a bad price for a stroker. A few other things will be necessary but to me, they're just maintenance items. The headers are already in the car, throttle body is already bored, the 19# injectors are already in, and the m30 afm is done. I also just recieved a racing dynamics straight pipe with resonator. I figure by the time this is installed and ready for next year's track season, I'll be having a bit more fun.
                        Driving is the only way to go faster....
                        • MattE30
                          • 1520
                          modifiede30....what about pistons and rods?
                          97 Cosmos M3
                          • modifiede30
                            • 1208
                            Crank, rods and pistons are all from the super eta. However, I may see if I can find alternate pistons from a european model to raise compression. The compression from the super eta is 8.5:1. You can bring this up to 10.0-10.5:1 with european 528e pistons depending on year. Remember that the super eta is essentially a stroker mechanically, except for the cam and valve springs of the head. Other than these components, its a stroker (of course you need the "i" intake and ecu components).
                            • MattE30
                              • 1520
                              how much was your eta engine you bought?
                              97 Cosmos M3
