Yesterday I was working in the dash to replace my recirculating and AC button. I also removed the center console to put in a short shifter. Got the dash back but the center console is still removed. It was getting late so I attached the switches back into the plugs and now both windows do not work. I replaced every fuse in the fuse box only because they were looking old. So I know the fuse is good! Ideas?
Windows are dead....ideas?
Did you accidentally hit the circuit breaker button on the dash to turn off the switches? Both switches should light up when your lights are on.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
