Fuel hose question..
  • BS87
    • 1606
    In my 84 325e... fuel line is starting to go. Tthe one that goes from the top of the fuel filter to a t join and then the fuel rail.... is it 7mm or 8mm? thanks for your help.
  • Jordan
    • 12916
    I believe 8mm. However thats pointless, because 99% of auto parts stores dont stock metric hoses, only gay american standard ones. Find one of similar size, and be on your way.
    https://mtechniqueabs.com/
    • RedBaron86325
      • 386
      I believe that it is 8mm, but I'm not exactly sure. I am running 3/8 (9.5mm) and it is a little big for the oem fittings, but does work just fine. 3/8 high pressure hose was easier to find on a Sunday afternoon and later found out it was about $1.50/ft cheaper.
      Don't forget the good things Hitler did.
      • rs4pro3
        • 5808
        8mm jsut looked at the meter of brand new line sitting in my room that I buaght last week at the dealer
        85 325e 2.7 ITB'd stroker
        • BS87
          • 1606
          Alright thanks for your help guys.
          BTW Jordan, i have both the 7mm and 8mm availiable to me.. just forgot the measure ment >_<
          • BS87
            • 1606
            Ehhehe... got it all installed... who'd have thunk it would run alot smother when it was getting the proper supply of gas, instead of having it leak out the tube and evaporate :oops:
