This morning on my way to work I noticed that the trip odometer said I had only traveled 43 miles on my current tank of gas. This seemed a little low considering I had under 3/4 of a tank, but I chalked it up to driving it hard and the slope I was on at the moment. I looked back about 10 minutes later and it still read 43 miles. So now I have to deal with a broken odometer (both the trip and regular odometer stopped).
Coincidently I was going to take my gauge cluster out next week when I get time to fix a light that had gone out. The light had gone out before, about 6 months ago and I found the source of the problem to be a hairline crack in the gauge cluster circuit board. I soldered the connection back together and it has worked since then. Then a few days ago I turned on my lights and again the right side of my gauge cluster wasn't lit, along with the clock in the middle of the dash.
I'm pretty sure I know how to fix the light problem, but I'm looking for guidance on the odometer issue. I've done a search and it seems that the main source of problems is the gears, which I can get from odometergears.com however I don't want to spend $75 on some gears then open up my odo only to find my gears are perfectly fine. I also would like to avoid taking the gauge cluster out twice...Could someone enlighten me as to what other sources of problems are? I've heard SI batteries, but I don't think it's those (not based on anything). It's not the sender from the diff, cause my speedo still works.
Thanks
Thanks
