Bouncing Idle problem, unanswered at gay bmw-forum
  • pogiboy9
    • 475
    Having bouncing idle problem on cold start
    replaced icv
    replaced idle module
    checked coolant temp sensor
    need more ideas or common problems
    and maybe solution.
    Also heating problem only on idle,
    ideas i have
    -radiator isn't flowing correctly
    -expansion cap (radiator)
    things i've done
    -checked circulation tempature while running on radiator
    and it was cold at the bottom radiator temp plug (sorry forgot the name I'm out of it)
    and it was hot, but the top one is about 40 degrees colder... \= help ?
    http://www.decal-spec.com
  • Erick
    Official R3V Drifter
    • 11169
    What year is your car?
    Could be the O2 sensor ( my case right now )
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • Jand3rson
      • 37587
      I don't think so. The o2 sensor in my car was completely dead (the 88 325) and my idle was just fine. The only time I had an idle problem was when my ICV died outright.
      • Jordan
        • 12916
        And I wonder why no one has answered it yet....
        You need to tell people what engine you have, what year and model car you have etc. None of us are mindreaders.
        https://mtechniqueabs.com/
        • 86325e
          • 228
          Check for vacuum leaks or a torn AFM boot.
          Does your ICV feel like its buzzing when you put your hand on it?
          Eric
          85 325e M50 and auto to manual transmission conversion...
          • BavarianBimmer
            • 951
            First of all what type of engine do you have ?
            IMO it seems more like waterpump probs or a bad flow, do you've done a flush ?(heating probs on idle)
            1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
            1997 E36 328iT
            1990 E30 325iT 24v SOLD
            1989 E30 325i 2.7i M-Technic II SOLD
            • elemental
              • Jan 2004
              • 112
              Checked the little things like, OIL Cap for a vacume leak or anywere else for that matter? I would have to start there if you havnt allready done that.
              • RedBaron86325
                • 386
                bleed the cooling system
                Don't forget the good things Hitler did.
                • randywalters
                  • 399
                  Pull up the fault codes.
                  Randy Walters
                  2021 Mazda 3 Sedan Premium AWD
                  1988 325is (w/89 bumpers, recently sold)
                  1989 325is (Broadsided long ago RIP)
                  1996 328is (Sold to Matt J)
                  2003 530i Sport (Spare car now)
                  2005 X3 (little woman's car)
                  Driving Instructor BMW CCA L.A. & S.D. Chapters
                  Multiple L.A. & S.D. Region SCCA Autocross Championships
                  • pogiboy9
                    • 475
                    Wow.... I'm staying here LOL leaving bmw-forums, seems like only i answer their questions and i leave one or 2 questions and no reply.
                    Well to whoever said o2 sensor,
                    -I've replaced it
                    LOL and for everyone
                    -'84 325e 2.7L
                    -lol i could've done the E to I swap but couldn't find a Junk 325i
                    -i've already resurfaced the cylinder head and port polished :)
                    Vaccum Leaks
                    -Thats my next deal
                    -i've run tests on all the ICV
                    -Coolant temp sensor
                    -replaced both ICV and MODULE
                    -Ordered the radiator expansion cap
                    Flushing the radiator is my next step,
                    if not flush just replace it.
                    • Werksmini
                      • 1658
                      Ajust the valves? I did it and now the CRAZY idle is gone but it says at like 2000 for a while... dont want to jack your thread but check into that. Maybe a valve cover gasket?
                      I bombed Korea every night.
                      • Saul325is
                        • 819
                        My first guess would be ICV, but since you replaced that then your best bet is the O2 sensor, but you replaced that. I HAVE THE SAME PROBLEM, ever since I used an e34 M50 boot (because im running an M30 AFM). Since i rerouted the ICV, ive had a bouncy idle. My guess is a vacuum leak, near the ICV. This is because im running a smaller vacuum hose from the ICV to the TB(so there must be a small leak). What I would do is just check all the hoses and listen for any leaks.
                        -Saul
                        Saul
                        01 330ci Daily Driver
                        89 332is Auto-x Friend
                        95 M3 *SOLD*
                        87 325is *SOLD*
                        • 86325e
                          • 228
                          I'm still leaning towards a vacuum leak.
                          However, here is an idle FAQ that I found useful when I was troubleshooting this problem with my 86 eta. At the time I replaced the ICV, ICM module, and all vacuum hoses and still had the problem. I went through this FAQ electricly checking everything with my multimeter and found out that there was a brokem wire in the connector that connects to the ICV (Thats why I asked if you put your hand on it to see if you feel it buzzing). BTW did you replace your ICV and ICM with brand new units or assumed working used units?
                          On the O2 issue. Does the idle bounce with the car in either closed loop or open loop mode or both?
                          Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
                          Eric
                          • rs4pro3
                            • 5808
                            My friend had a bouncing idle on his 86 325, after he replaced the Idle module it smoothed out but not perfect, His o2 sensor was bad so he is going to replace it and see if it will help.
                            85 325e 2.7 ITB'd stroker
                            • skat 325is
                              • 296
                              I replaced the O2 sensor, ICV, and bought a used AFM and it went away, i think it was a faulty AFM.
