Well actually i guess its the clutch pedal or i dont know. This morning i start my car and go to put it into first and i notice that the clutch pedal has very little pressure. Almost liek when you bleed brakes and you can push all the way to the floor with very little happening. So i had to press the pedal to the floor super hard in order to change gears. I was at my friends house over night about 10 miles from my house and while i was driving it stayed like this. Is it as simple as jsut ajusting the pedal? or could i have some major problems comming up. Clutch doesnt slip and is fine.
Clutch Problems
Tags: None
You need a new slave cylinder. The seals are leaking and that's why you have no pressure.Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholic -
+ 1 I know my slave is leaking on my turbo car, I saw it with my own two eyes a couple weekends ago. I have a new one coming on Monday to replace during spring break. They are only liks 30-35 bucks from BMA...Last edited by backtrail69; 03-10-2007, 09:27 AM.:: PNW Crew ::
'87 325 4dr, '74 2002Comment
Try to get the slave fixed asap. You don't want the brake fluid to go into the bell housing and onto your clutch disk. This = slipping.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
