About pulling the intake manifold from the head
  • llll1l1ll
    • 782
    Yeah, you all prettymuch hate me here from my last post about my broken rocker arm and missing headbolt. Anyway, I really need to know what the fuck this thing is connected to the intake manifold. I have all the bolts off and everything detatched fuel-wise; except for this one thing. It's directly in the middle of the manifold, on the bottom, and it looks like its connected to the block. But like, where its connected, it looks like a spring? Man, its really bothering me because I can't get the head off without removing this thing. Or maybe I can get around it somehow. Its metal, too. Not a rubber hose like I thought it would be. Does anybody know what I'm talking about? Have any idea how to deal with it?
    Me: "I can't wait to redline my car!"
    Mark: "Didn't you just break a rocker arm?"
    Me: "Yeah, I don't think I've learned my lesson."
    Mark: "You never will."
  • DrMcDave
    • 1793
    i think i am in the same boat, i have all the nuts removed but i can't get the fucking thing off. What else is holding this thing on? I want to paint and it and clean it up while we have my head out, which i might add is not out yet due to the exhaust manifold bolts.
    • llll1l1ll
      • 782
      The exhaust manifold bolts were easy, they just took some contortionism. Make sure that each night you generously coat the bolts in a WD-40-like compound. I used WD and Liquid Wrench. The bolts should come right off with some nudging, coaxing, and brute force. As for the intake manifold, I really need to know how the fuck this thing comes off. The piece at the bottom is holding it on, but there's no way I can get grip on that thing. Plus its metal, and has a springy thing at the bottom. It's really pissing me off and I'm really looking everywhere for answers. I'm starting to get desperate!
      • Jand3rson
        • 37587
        That's "The Spring-Loaded Tube of Death"!
        So-called be cause if you aren't careful, that thing will fly out and smash you in the face. It's also a BITCH to get out of there. I reccomend getting some of those work gloves that have rubber on the grips, and just going to town on that sucker.
        • Bryson
          • 1490
          push the tube straight down about 1" to clear the intake manifold, you can also buy a tool that will hold it down while the intake manifold is out. Make sure to buy new o-rings for it once you pull it because they are usually hard as rock. There are two o-rings, one is underneath a washer connected to the block
          edit: when installing, lube up the top of it with vaseline and pull upward nice and hard to get it to set, it won't set itself
          • James Crivellone
            Head Janitor
            • 6305
            God I fucking hate that thing, had to have somebody hold it down while I was rocking the manifold back and forth to get it off....
            • Ryan Stewart
              I Love Miatas
              • 8978
              Did you guys try taking the thermostat housing off?
              I took that off and that allowed a little angling of the manifold and that tube just slid out.
              Im now E30less.
              • llll1l1ll
                • 782
                You guys totally rock! Thanks! It looked kinda springy, but I was like, "Wtf is a spring doing down there?" Anyway, I'm sure the gasket set I bought has the o-rings in it. If not, I can find them.
                Seriously, though. What does that thing do besides threaten to hit you in the face?
                • Ryan Stewart
                  I Love Miatas
                  • 8978
                  allows crankcase pressures to make it up to the valve cover/manifold. That is how the oil makes it into your bellows.
                  Im now E30less.
                  • skat 325is
                    • 296
                    one question, if that tube isnt installed correctly, it'll leak oil right ?
                    • Jordan
                      • 12916
                      Alot of oil.
                      https://mtechniqueabs.com/
                      • James Crivellone
                        Head Janitor
                        • 6305
                        You would have a fountain in there.....
                        • skat 325is
                          • 296
                          lol ok, thats what i thought :P
                          thanks
                          • DrMcDave
                            • 1793
                            does that mean i should drain the oil out? god knows enough has leaked into my engine anyway. hmm i need to look and try to understand what you guys are talking about w/ this spring. i didn' t notice one, but i didn't look very hard either. someone wanna post a picture?
                            speaking of removing heads, i found about 5 other things to fix "while i was in there"
                            like hoses that look sub par and i found another leak. possibly power stearing fluid i didn't really investigate it yet
                            • DaN
                              • 1265
                              Anybody have some close up pics of the ends of the tube, and holes in the intake and block?
                              I'm just curious how this thing is designed. I had my cylinder head off a year ago and that tube has been leaking oil for a while, I put new o-rings in it, but I don't recall setting it, like someone said above.
