wiring harness
    wiring harness
    would the ignition wire set from an eta work in a 89 325i?
    It would work technically, but it would lack the impulse sensor ring on the #6 plug wire, so it won't run 100%.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
      Oh, i was wondering what that was and that wire was the reason for the my question. i guess i better start looking for a I ignition wire set. thanks adamF
        You could also retrofit the impulse sensor from an i wire set, but it really isn't worth it.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
