666 plate, steering rack snag
  • Jordan325iC
    • Aug 2005
    • 1697
    I jacked up my car the other days and tried to install my new 666 fab skid plate.
    I got stuck on this first step, remove the steering rack bolts.
    They were real sticky. I prepped them with PB blaster and then took a breaker bar to the right one. It was odd, I could turn it but it never really came loose, it still had a ton of resistance. This went on for a few turns with the bar then I finally "broke" the bolt loose, and it would turn freely, but it would not come out no matter how much I turned it. It stayed where it was
    The left one had the same symptoms, but I never got the point of breaking it loose.
    What is happening? How do I get these damn bolts out?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • PeaveyBassist
    • Sep 2004
    • 3511
    There is a nut on top of them. You have to hold the nuts while you turn the bolt.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • DEV0 E30
      • Oct 2004
      • 8871
      Will
      Yep.
      After you spot it you'll feel dumb. I did. They are sort of hidden.
      Are you going to use the supplied self tapping screws?
      • jon volk
        • Dec 2004
        • 524
        Originally posted by DEV0 E30
        Yep.
        Bolts, washers, and self locking nuts are now supplied. I believe he has that setup.
        '92 MTech cabrio: Tesla P85 powered
        IG: telsa_bimmer
        '95 Alpine M3 5.3 LS, Precision 7675, TH400/Gear Vendors OD
        10.4@136 pump gas at 3530lbs. (SOLD)
        • Jordan325iC
          • Aug 2005
          • 1697
          Yea, I got it. The only thing that is different w/ the bolts instead of the screws is you have to remove the large plastic front engine undercarriage cover in order to get to tighten the front skidplate nuts. I just installed the skidplate and then fit the undercarriage cover over it. I'll have pics tomorrow after I go rallycrossing.
          '88 325is
          BMWCCA 380364
          • Jordan325iC
            • Aug 2005
            • 1697
            Here's a picture of the skidplate installed w/ nuts&bolts and the plastic undercarriage cover over it.
            '88 325is
            BMWCCA 380364
            • ACHTUNG
              • May 2005
              • 2397
              looks good.
              1989 US E30 Cammed S52
              Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
              • BimmerToad
                • Sep 2004
                • 1537
                do oil temps increase with the skid plate installed?
                San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
                • turbo_negro69
                  • Dec 2006
                  • 468
                  I left that damned cover off. looks good. Big thanks to Jon for changing the setup from screws to nuts and bolts!:-D
                  91-318i SOLD : (
                  91-318IS for sale
                  95-740i DD
                  84-Monte carlo SS Under construction
                  90-T-bird Supercoupe DD
