Clutch slave
  • Nj85'325
    • Dec 2006
    • 90
    Clutch slave
    So im replacing my clutch slave, and the bottom nut was easy to get off but, the top nut is almost impossiblt to get to. anyone with ideas or tips, this has got to be fixed today.
  • Mike325
    • Mar 2006
    • 3685
    Get an extention on there. That is how I do it.
    You could also tip the trans back. Don't need to do this tho.
    Originally posted by Kershaw
    • Rocla
      • 922
      13mm socket-3/8" medium extensioner, universal joint and antoher extension should do.
      Current:
      BMW 320i 2d 2.0 m20 -88
      BMW 325i Cabriolet 2.5 m50 -88
      BMW 316i touring 1.6 m40 -90
      BMW 320i 4d 2,2 m54 -01
      • Nj85'325
        • Dec 2006
        • 90
        well the bottom stud broke and went back into the trans.... how do i get it out?!
        • NC325iC
          • Mar 2004
          • 6565
          youre F'ed bro youll probly have to drop the trans for that
          • backtrail69
            • Jul 2005
            • 4471
            You can probably get it from the lower bell housing cover. Just take that cover off. Universals and Swivel extensions are a savior...
            :: PNW Crew ::
            '87 325 4dr, '74 2002
            • NC325iC
              • Mar 2004
              • 6565
              nah the flywheels is in the way, you cant get to anything from back there
              • Nj85'325
                • Dec 2006
                • 90
                Yea... flywheel is in the way, not enough room to even get a brazing rod in there... last chance befor i drop it...
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  If you can find one... a magnetic on a bendy stick might work IF you can get it between the flywheel/bellhousing. Otherwise... youre screwed man. Sorry.
                  Will
                  RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                  Welcome e30 (brilliantrot '90 325is) 12/23/06
                  DaveCN = Old Man
                  My signature picture was taken by ME! Not by anyone else!
                  If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                    • 37832
                    How in the world did you break that stud? The slave cylinder is a really simple job.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • bddog
                      • 351
                      What a drag. I can't think of anything that would be of any help.Split them a little and use magnet,rod,etc. Good luck.
                      Roccla has the right idea.
                      A universal socket is the key tool though. The uni socket, a medium extension, a universal, then another extension. It will get you in most anywhere, with leverage.
                      It changes the angles, gives you more feel and keeps you from stripping nuts and breaking studs.
                      Hold the extenion next to the ratchet, when you are ratcheting. - Steve
                      • Nj85'325
                        • Dec 2006
                        • 90
                        thats actaully the 3rd bolt/stud i have broke on this car... i think i can get a magnetic stick threw the stud hole, if i get it out im gunna tap the hole and re enter stud
                        • NC325iC
                          • Mar 2004
                          • 6565
                          if youve got the slave off you can probly get a magnetic deal through... oh wait the lever is in the way...
                          nm your screwed
                          • DJB
                            • Oct 2005
                            • 195
                            I'm pretty certain that you are going to need to drop the transmission to do the job correctly. These are bolts with knurled shoulders. They come out with a few modest hammer hits. As you can see, you'll need access to the other side to insert them. Once in place they are easy to seat with a nut, but you can't get past the flywheel to put them in place.
                            I don't expect that tapping threads in the holes will work, and it's a one-way trip to find out. You'll be enlarging both the existing holes and the mounting holes for the clutch slave cylinder. The case is a light alloy, and the clutch requires a lot of force. Once you strip the threads, it's either the next bolt size up or time for a replacement.
                            • Nj85'325
                              • Dec 2006
                              • 90
                              Guy down the road from me is a transmission guy, he said that i would be able to tap it, but i would have to use a bigger bolt, also he mentioned something about drilling a hole in the bottom of the tranny?! I know hes been doing this a long time but he said its a common problem and that hes done it befor. Im way to scared to do that so il try the magnetic stick,
