choking at high speeds? any idea?
  • e30hereicome
    • Dec 2006
    • 115
    around 55+ car starts to choke, kind of feels like as if the exhaust was backfiring but i would actually feel it choking. any idea what it could possibly be? i was told that it might have been my m20 airflow meter, but i swapped it with an m30 afm and it still ran the same way, choking. acceleration wasnt smooth. plain ol cough cough. lol anyways let me know what you guy think or suggest i do. thanks!
  • BimmerBall
    • Oct 2006
    • 185
    mine started choking at about 80, after that it just gave up trying to go any faster. if you pushed it harder, it would just sputter and die. i had an unbelievable amount of sediment, rust, and general shit in my gas tank so i replaced that and the in-tank pump and that solved my problem.
    • e30hereicome
      • Dec 2006
      • 115
      hmmmm.... thats weird because the PO had changed the fuel tank. maybe the fuel filter or fuel pump? i smell gas in the right rear wheel well, any ideas?
      anyone else know what that choking problem is?
      • Court M3
        • Jan 2004
        • 6713
        got the same problem, fuel pump is only about 5km old. Changing the in tank one next.
        Continuous For Sale Thread
        323i s50
        • JAM
          • Feb 2007
          • 524
          change your fuel filter!
          its easy, cheap, and if you've never done it, do it. that may just fix your problem
          also, if your smelling gas from the rear driver side wheel well, that is exactly where your fuel filter is
          the choking problem is most likely a fuel filter clogged with shit!
          CHANGE IT!
          Originally posted by Mr Watsonsilver
          driving boards?
          • Court M3
            • Jan 2004
            • 6713
            CHANGE IT!
            fuel filter or intank fuel pump? On the early 323i the filter is under the hood. intank fuel pump is under seat?
            323i s50
            • JAM
              • Feb 2007
              • 524
              on my 1990 325is the fuel filter is right in front of the drivers side rear wheel well
              driving boards?
