air temp connector
  • Matto
    • Jan 2004
    • 800
    air temp connector
    I am installing a OBC (not 6 button) and I cant find the ambient air temp sensor connector, where the heck is it?
  • Tangent
    • Mar 2004
    • 476
    Should be under the front bumper on the left side.
    • fporro
      • 1859
      or behind driver headlight, round sahpe, black, conectors 1 male, 1 female.
      • Matto
        • Jan 2004
        • 800
        Isnt there a connector under the driver side dash to hook it up to the OBC?
        • fporro
          • 1859
          yes, there's one thre too, but closes to switch will be near abs pump. or cruise control actuator.
          • Matto
            • Jan 2004
            • 800
            What does the one under the dash look like? there is a big white connector box under there, looks like it could be part of that but im not sure. I've got the connector from the wiring harness sitting under there so I don't want to go running unneeded wires.
            • James Crivellone
              Head Janitor
              • 6302
              There should be a 2 conductor white plug that connects to the old OBC (if you had one) if you only had the clock, then you may have to run a wire to the front of the car...
              That connector is located in the main harness that is to the left of the ABS Computer, you should see it tied up there..
              • Matto
                • Jan 2004
                • 800
                I can't for the life of me find the connector, anyone have some pics? Also when i turn my lights on the OBC goes dark, whats with that?
                • Jordan
                  • 12912
                  Find the drivers side foglight wires. Follow them back up to the harness. The connector for the temp sensor should be right next to where the foglight wires disappear into the main wire bundle.
                  https://mtechniqueabs.com/
