hey,
has anyone ever had problems with there auxiliary fan. If so, what did you do to fix it.
My fan been messed up for a long time. I've done a couple thing to try to fix it. I did the electrical test were you jump the battery straight to the fan and test for low ideal and high ideal speed. the fan cames on at high ideal speed but not low ideal speed. so i spent 30 buck and got a now switch and that didn't fix the problem. so I i pull an auxiliary fan from a wrecking yard and tested it on my car and it did the same damp thing. so i'm kinda stuck on what to check next.
