Anyone try these?
    Anyone try these?
    Seems interesting? He says he will refund if it does nothing?
    the description is really convincing, but i'm not going to be the first to try.
    R.I.P 07/01/09 - 04/23/10 :(
      I highly doubt you could get your money back for those.
      Will
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        I will be the guinea pig.
        It's 30 dollars :)
          Just get the urithaine bushings. I don't know why he said that they were $250 for good bushings. It would be nice if thoes were like a five minute on/off deal, but they are not. If I was doing my rear subframe bushings, which I did a few months ago, I would not fuck around with something that is going to be a bitch to get out if they are no good. My 0.2. /rant.
          Originally posted by Kershaw
            You can put them in easily... You don't have to drop the subframe. Take out the bolt, remove the cover and locater assembly and slide these in. Reinstall...
              It seems logical, but I am going to just replace the stockers instead ..
                Yah, I just don't want to do subframe and trailing arm bushings right now :(
                Guy is in Atlanta too...
                  That does not sound to bad then. See how it works.
                    I will see... I will let everyone know!
                      You guys realize all it is is pieces of PVC pipe, right? It's like $1 worth of pipe and 10 minutes with a saw.
                        It looks like that yes. I however know these will fit and worthwhile to give a try. See what Is up :)
                          I'll verify that they DO work and they DO make a difference. IE & others sell urethane inserts for the 2002 sub bushings like that....
                          Here's the catch. IF you shove them into a shitty wasted rubber bushing you'll notice a little bit of a difference but its only a matter of time till it's worse than where you started because it'll accelerate the wear. Catch is you gotta use new OE rubber mounts and those to get the same effect as soft urethane available today.
                          They do work though... No affiliation to the seller.
