No spark/fuel
  • 88e30is
    • Feb 2007
    • 690
    No spark/fuel
    Not getting any spark or fuel in my 88 325i. I have power on both wires on the coil I have power to the injectors. I have a new cap, rotor, plugs, wires, coil, battery. The fuseable link was broke so I just jumped it with a wire for now. The car turns over good it just doesnt start due to no spark or fuel. Any other ideas? Are these issues related in any way maybe a relay or something. Please I need to get this things back on the road.
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Bad DME, DME Relay, or Crank Position Sensor.
    • 88e30is
      • Feb 2007
      • 690
      Where is the DME relay?
      • RobertK
        • Jun 2005
        • 5864
        Under the hood I believe separate from the fuse box where the fuel pump relay is located.
        • 88e30is
          • Feb 2007
          • 690
          Is it one of the three where the fuel pump relay is?
          • 88e30is
            • Feb 2007
            • 690
            Got it!!!! The Crank Possition Sensor was plugged in to the wrong plug. The plugs are the same and right next to each other but one is turned the other way around so it would make sense to be plugged in the way I had it but I guess not. Wow I feel like a total dumb ass but thank you very much to everyone that helped!
