e30 4 to 6 cylander swap
  • denisbmwm5
    • 347
    Yes tha would be great rs4pro3, i really apresiate it. post tehm later if you can
    thanks
    • rs4pro3
      • 5808
      Ok here you go, I can't quarente it will work as I haven't tested it yet but anyways.
      318i Chassis -318i Engine- 325i Chassis-325i Engine- Function for 325i
      White/blue -White/blue- White/blue- White/green
      violett/green- Blue/White- Violet/green- Blue
      Black/brown-Brown/green- Black/brown Brown/green
      Violet/red- Green/violett(lg)- Violet/red(large guage)- Green/violet(S&L guage)
      2(sg) blue- Blue- Blue- white
      Blue/yellow- Blue/violet Blue/yellow- black/white
      Green/yellow-Green/yellow(lg)- Green/yellow(LG)- Green/white
      Green(lg)- Green(lg)- Green(lg)- Green(Lg)
      Black/yellow(S&L guage)- Black/yellow-black/yellow-Black/yellow
      Yellow/white-White/black- Fuel rate output
      Black- Black- Engine speed output
      Brown/black-Gray- Check engine light
      Blue/black- Green/yellow
      White/black- White/black
      Red/yellow(sg)
      Brown/violett- Brown/violet-Brown/violett-Brown/violett
      sg=small guage
      lg=large guage
      s&L= both small and large guage
      Hum the format is all screwy just email me and I'll email you the info as I did it in Excell.
      85 325e 2.7 ITB'd stroker
      • denisbmwm5
        • 347
        OK guys thanks a lot i got it. the car drives crazy. drifts all over the road. the power the 325i motor ptoduces is crazy. I still got one problem: when i drive 10mph + the shifter shakes hard. could this be the drive shaft because i didnt use luck tight stuff on it???? I think its the drive shaft, jsut wanna see if you guys had same problem. thanks
        • rs4pro3
          • 5808
          email sent.
