Life to a tighter shift, death to the bitch clip.
  • Jordan
    • 12916
    This morning I felt like fitting my 1.9L Z3 kit to the tranny, and making sure everything was good and tight before getting the tranny in the car.
    After fitting it I decided the amount of slop in the shift knuckle, and the rubber bushing that mounts the shift carrier was unacceptable. So heres what I did.
    I took the shift knuckle sleeve off, and drove out the pin. Took the knuckle off the shaft. Replaced the shaft seal while I was there, because I knew it leaked. The small rubbery cap inside the knuckle was virtually gone, deteriorated from old age, and grease. I removed it and replaced it with a 3mm long section of fuel hose. I then pressed the knuckle on for all I was worth (hella hard to get on all the way with that extra rubber in it) then with some luck I managed to drive the pin back in and replace the sleeve.
    When all was said and done, the knuckles side to side movement was reduced 2/3, and it was nice and stiff.
    Onward to the next task>>>
    Who here has tried to remove the bitch clip with the tranny still in the car? (raises hand) Its a BITCH!! Honestly there is no reason for it, poor engeneering IMO. Also in this area is that black rubber bushing on the end of the shift carrier. It is what is pinned in place by the bitch clip. Once installed, even if a brand new bushing, it allows for a horrible 30º side to side movement in the shift carrier... all of that translates into slop for you and me, and it is unacceptable.
    I took the carrier off, layed it in the vise and pressed out the bushing. Took it with me to the hardware store and picked up a brass bushing of quite similar outer diameter. When I got the brass bushing home I found it was too big to be pressed in, even by force. I took the Dremel out, with a standard 80grit sanding drun on it and quickly ran it in and around where the bushing needed to be. I didnt remove much material at all, just cleaned it up and made it smooth if anything.
    After that the bushing pressed right in, with a bit of force, but just right IMO. I centered the bearing on the carrier then sized it up to where it had to fit on the tranny. It was a bit too wide. So i cut 2mm off one end, and filed it down smooth again. Now it fit perfectly, again not super hard to press in, but more then tight enough.
    I found a bolt in my spare hardware bin that was the exact same size as the inner diameter of my new brass bushing. I drilled the 2 holes on the carrier mount ears to be the same size as the bolt.
    The I just drove the carrier into position, pushed the bolt though, and tigheted it up.
    After all that I was left with at MOST 2º of side to side slop in the shifter assembly. Which is basicly nothing. I'm happy, the bitch clip is gone, and the shifter is one tight mo fo.
    Pictures:
    https://mtechniqueabs.com/
  • rwh11385
    lance_entities
    • 18403
    just wondering, is the so called bitch clip the reason the shifter will be able to lean side to side even in gear? I think this is sloppy and..... if it is..... you remove this "bitch clip" to stop the "sway" if you could call it of the shifter?
    Keep up the good work Jordan..... you say you engine and tranny wil be in by friday? Tight.
    • Jordan
      • 12916
      The bitch clip is solid... it doesnt contribute to slop. The black rubber bushing that goes where by brass bushing is aids in adding slop.
      To anyone that has their tranny out of the car, I would highly recommend what I have done here. It must be done out of the car tho.
      When I am in gear, I have NO side to side, up and down, or forward to back slop.
      NONE, I mean absolutely NONE.
      Neutral is a circle between the size of a nickel, and a quarter
      • RedBaron86325
        • 386
        < raises hand > Been there. That thing is a mother. Last time I pulled an engine/tranny out, I had a hard time with the 'bitch clip' with the tranny out of the friggin car. I have no idea how I did it on my car, back in the day (1995ish), with the tranny in the car. I faintly remember a lot of cussing, kicking, complaining, banging, yelling, screaming, and arguing with my car that day. Luckily, for my car's sake, I don't live on a cliff.
        Don't forget the good things Hitler did.
        • rs4pro3
          • 5808
          Nice, for somereason the Bitch clip didn't give me a hassle when I removed the tranny to do the clutch I jsut left the shifter assembly attached to the car. I've got realy skinny arms so that helped. I'll ahve to do this mod to my spaid shifter in the garage so that when Ever I rebuild it I can stick a nice slop free shifter in.
          85 325e 2.7 ITB'd stroker
          • Jand3rson
            • 37587
            Re: Life to a tighter shift, death to the bitch clip.
            Ahhhh, one more part of my car that will live on in Jordan's. Makes me happy. :D
            I WILL be doing this to my E30 when I get it.
            • Jordan
              • 12916
              You mean I will be doing it again, but for your car next time.
              • Bryson
                • 1490
                Brilliant, Jordan. Is there a part number for the brass piece or an interior/exterior size you can give us so that we too don't have to match by hand? I'd really like to do this as I have an M coupe lever and it still has a quite large amount of play.
                • Inspar8r
                  • 301
                  Damn, i was hoping not to have to remove the tranny. Look like i have to now. Maybe i'll try to lower it so more and see what happens.
                  My side to side play is horrible as well, but i'd prolly be happy with the new rubber bushing.
                  Jordan, what is this bitch clip? The clip that hold the shift lever to the selector rod??? Mine are easy as pie, so i'm guessing it has to do with the selector rod and the tranny itself.
                  Let me know, i'm getting under the car again tomorrow..
                  Nick
                  87 325 5MT
                  02 IS300 5MT
                  • Jand3rson
                    • 37587
                    Yeah, yeah, yeah... :D
                    • PeterCip
                      • 402
                      Jordan,
                      I wish you had told me about this a week ago...I just got my tranny bolted up and I don't want to have to take it off again. do you think there is any way to do this job without taking the tranny off? not the shift knuckle part but the bushing. I put a new bushing in and I was NOT happy wiht the results...
                      • RedBaron86325
                        • 386
                        It can be done without removal of the tranny. If I can do it, anyone can. It is just WAY easier with the tranny sitting on the floor rather than in the car. With the tranny in the car, the space is very confined and you have very limited visibility of what you are doing. It isn't easy but it isn't impossible either. Be sure to take your Prozac before you start to counteract the depression while attempting this.
                        • Jordan
                          • 12916
                          The reason why this cant be done in car is because you need to enlarge the size of the hole's on the transmission ears. Good luck fitting a drill in the transsmission tunnel, and drilling perfectly straight and true.
                          • PeterCip
                            • 402
                            can you just get a bushing that will fit the stock "bitch pin"? do you know what OD the bitch pin is? I am sure I can have my machine shop make an insert to fit all the stock sizes..
                            Jordan good work on getting rid of the slop..I would have not thought of ditching the bushing all together.
                            • Jordan
                              • 12916
                              UUC sells derlin bushings to replace the stock black one. They cost money tho, and I didnt have it to spend, so i fabricated a cheap $2 solution, that most likely is tigher.
