Has anyone ever had their tank resealed. Any thoughts commments on how it turned out? thanks a lot guys.
fuel tank resealing
You can do it, depending on where its done. I would bring it to a pro because this is dangerous stuff (if your welding). Are you talking about the stuff from a parts store that just seals it up?
That stuff works pretty good, just remember to clean the area good before you start. That should only be a temporary fix. You should replace you're gas tank if it is leaking.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed. -
I am still using the tank I sealed a year or so ago with the u.s. tank stuff sold through por-15. was easy. worked perfectly.Comment
