Are the IVC from the super ETA interchangable with the i?
What IVC?
Check out realoem... There are a few different kinds. Most importantly is whether or not you have a two wire or a three wire one. I'd venture a guess and say that you can probably interchange all the 2 wires and all the 3 wires respectively. The manuals will tell you what voltages you need to expect at the 2/3 wire prongs. I would venture another guess and say that if they are both three wire (or 2 wire) and the voltages are supposed to be the same (and you test them and they are) then you can most probably interchange them.
