Turbo fuel setup
  • randomtask37
    • 3154
    Turbo fuel setup
    Im just wondering what kinda fuel management all you turbo guys are running.
    98 M3/4/5
  • Kavkazia
    • 394
    Depends how much boost you want to run, I will be running 4.0 Bar FPR and 19l/b injectors for now, and will see what happends at 10PSI.
    95' M3.
    90' 325i Turboed.
    87' 325eS Fixed.
    • matt325is
      • 409
      RIght now I have 32lb/hr injectors, IE adjustable FPR, stock fuel pump, megasquirt fuel management system. I'll run 12-15lbs with it.
      matt
      • PeterCip
        • 402
        19lb/hr injectors,
        Adjustable FPR set at 3.5 bar,
        Split second MAF conversion with ARC 2 fuel managment(adjustment)
        I had a little trouble with ironing out the fuel wrinkles but now the car runs great.
        Matt, why are you using 32lb/hr injectors? are you having a problem wiht fuel starvation?
        I have no problem running rich at WOT even when I was running 12-14psi...
        and don't you need a lower static pressure at idle with those injectors?
        And are you planning on using a water injection system to suppress detonation, or are you using SMT-6
        -pete
