How do I pull codes on an m20
  • dinanm3atl
    • Feb 2007
    • 7305
    E36 I know how...
    Can I hook a peake up to the diag plug?
    Let me know guys.
    Thanks!
  • Mike325
    • Mar 2006
    • 3685
    Ya, a peake will work with an 89. Same way as your e36. I have the FCXII and that goes down to 87+.
    Originally posted by Kershaw
    • dinanm3atl
      • Feb 2007
      • 7305
      Where do I get this item you speak of?
      • erik325i
        • Jan 2005
        • 3567
        You already have the tool.
        The Peake tool you use for your e36 should also work on your e30. I use my Peake tool just fine to check the codes on my cars. When Dan Peake gave me my tool, he said it would work for any BMW with an OBDI connection. The cars that only have an OBDII connection require the use of a different tool.
        -Erik
        • dinanm3atl
          • Feb 2007
          • 7305
          Oh cool
          • dumpedgti
            • 11
            Turn the key to the "on position" and press the gas pedal 5 times, making sure to go ALL the way to the floor! After the 5th time, release, and look for the check light to flash out a code... Worked for me, let me know if you have any probs.:-)
            • dinanm3atl
              • Feb 2007
              • 7305
              yah i gots it last night :)
              I forgot to plug in my o2 sensor after the shifter rebuild.
