steering assembly
  • jrobie79
    • Mar 2006
    • 2526
    steering assembly
    got a question about the front end suspension/steering, when i go over bumps in the road i can hear this hollowish metal clunking sound, and i thought maybe tie rods or ball joints, however i had my car jacked up the other day, and there is this joint in the steering column i noticed and i happen to hit it and i think the noise is coming from that, i grabbed on and shook it and it moved like a bastard, side to side and what not, shouldnt that be stationary, so i was thinkin that was causing the noise, and maybe that rubber piece that connects the two parts of that steering rod, i dunno the real names for this stuff, but i can get a picture to be more clear if needed.
    1991 318i ---- 308K - retired
  • Bimmerboy91
    • Feb 2007
    • 622
    some thing going on to. BUMP for this thread!
    • Mike325
      • Mar 2006
      • 3685
      That would cause that noise. You should get that replaced asap.
      Originally posted by Kershaw
      • jrobie79
        • Mar 2006
        • 2526
        you mean that rubber place would cause the noise, or what else of what i described would? what are the exact part names so i know what im asking or searching for? thanks a ton
        • Mike325
          • Mar 2006
          • 3685
          E30 325e STEER.COL.-LOWER JOINT ASSY</B>
          RealOEM.com Home => Select another car => STEERING => STEERING COLUMN
          No. Description Supplement Qty From Up To Part Number Price Notes i ONLY APPLIES TO AIRBAG
          ONLY APPLIES TO HYDRO STEERING01LOWER JOINT ASSY109/198932311153593$175.2102SWIVEL JOINT132311156348$135.0403BUSH132311157692$18.0804 CUP132311156227$7.9205GASKET132311156226$1.9806BRA CKET132311156225$1.4007HEX BOLT WITH WASHERM8X20-Z3-1207119915178$0.6108HEX BOLTM8X38332311122041$0.3309WAVE WASHERB8707119932095$0.0410SELF-LOCKING HEX NUTM870712992271611BUSH132311114508$0.5812UNIVERSA L JOINT107/199532311153993$19.5312UNIVERSAL JOINT132311093705ENDED13FIT BOLT432311153995$3.08Notes:
          I think the U-joint it's self would cause your problem. The rubber being bad would not help the situation tho.
          • jrobie79
            • Mar 2006
            • 2526
            awesome thanks man, how would i figure out for sure if its that swivel joint, i mean i can grab the part listed as part#1 and it shakes so im assuming its the swivel joint,
            and also i dunno about the price tho, im wicked poor, so maybe ill go find a lower mileage one at the junkyard and try that, if it works ill keep it till i hear the noise again, if not then ill get a new one.
            • Mike325
              • Mar 2006
              • 3685
              That is a good idea. Try and find a used one.
