324td
  • erehemantresni
    • 136
    324td
    Has anyone ever modded this engine? Is it worth while?
  • Sean
    • 5793
    There's a ton of eta owners that would kill for that crankshaft.
    That's all I really know about the engine though. Sorry I can't be more help. :?
    - Sean Hayes
    • Stu Mc
      • 4083
      The only worthwhile part on the M21 was the crankshaft, because of the 81mm stroke and because it is forged. It is now obsolete since we have up to 89.6mm forged cranks available that fit M20's.
      • E30godz
        • 1524
        is there another 81mm crank that is forged that fits M20's, and is somehow better? if not, then it isn't obsolete.
        people may want an 81mm stroke over the 89+ stroke for whatever reason
        • decay
          • 5637
          what about the exhaust manifold? same flanges as an i head?
          past:
          1989 325is (learner shitbox)
          1986 325e (turbo dorito)
          1991 318ic (5-lug ITB)
          1985 323i baur
          current:
          • RedBaron86325
            • 386
            NO, top mounting holes will fit, new bottom holes need to be drilled to fit the studs. Ports 3 and 4 match, 2 and 5 are 2mm off, and ports 1 and 6 are 5mm off. It will work with modification, but a custom manifold will flow much better.
            Don't forget the good things Hitler did.
            • skat 325is
              • 296
              IMO the td manifold is'nt worth the hassle, just make a custom one.
              • decay
                • 5637
                noted. thanks.
                past:
                1985 323i baur
                current:
                • Stu Mc
                  • 4083
                  Why use an 81mm stroke when you can use 84mm, 85.8mm, or 89.6mm :?:
                  The cars with 81mm stroke don't pull near as hard as those with 85+.
                  • diegom6
                    • 4447
                    like what cranks Stu? The m50 US M3?
                    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
                    • Stu Mc
                      • 4083
                      '95 M3 = 85.8mm
                      '96-'99 M3 = 89.66mm
                      '96-'99 328 = 84mm
                      all forged
                      • E30godz
                        • 1524
                        super steamy high revs dawg.
                        • Stu Mc
                          • 4083
                          With 2-valve curtain area and a timing-belt----nope.
                          You can build street M20's in stroker form, whether it's a 2.7, 2.8 or 3.0+, and it will have the midrange, with a cam and tuning it will make some top end, but let's leave the serious revver's to the 24v's.
                          I've driven 3.0 M20's and 2.8's. The 3.0's come on quite a bit earlier, but both run out of steam.
                          • matt325is
                            • 409
                            10 bucks says my 81mm stroke pulls harder than the 89mm stroke.
                            matt
                            • Rob
                              • 8166
                              that's cause you cheat matt
                              BEERTECH
